Is the numark mixtrack pro II not supported by djay? I’ve gone through the other threads with similar issues and nothing seems to resolve it. It says there are no updates for djay, and I can’t select built-in mapping in the midi/configure menu. If I upgrade to pro will it be compatible? I don’t want to spend the money to find out that the answer is no…
The Numark Mixtrack Pro II is natively supported by djay Pro (only). Try it out using our demo version. Get it here:
http://www.algoriddim.com/djay-mac/download
