Numark Mixtrack Pro 3 DJ Contoller,
I am using algoriddim on the iPad and want get a numark mixtrack Pro 3 DJ Controller I’ve heard it’s compatible with algoriddim how true is this and will it function properly using all algoriddims features
Hey there,
thank your for your post.
Unfortunately the Mixtrack 3 Pro is not supported by the iOS version because it is not a native iOS controller.
Besides that, the controller is working perfectly with djay Pro for Windows and Mac.
First of all thank you for your reply I just want to know if there are any other controller besides wego 3 that is compatible with djay 2 on the iPad Pro .
