Numark NS7 II support?
I’ve just returned back from BPM in Birmingham and had the joy of playing with the new Numark NS7 II…it is seriously good fun and a massive piece of kit. At the moment it’s paired with Serato, but I’m wondering…it’s a Midi controller…so perhaps (fingers crossed) it’s USB class compliant (like a lot of other Numark controllers) and therefore might get some djay 2 support in the future?
Those spinning vinyl platters and capacitive filters & EQs are great fun.
Also love to see NS7 and V7 natively supported by Djay Pro, thanks!
DJ Hombre, I fully support your request. That new NS7 II is an incredibly attractive tool with those velocity-sensitive pads and touch-sensitive knobs but also a lot of other features.
On the other hand, I really wish that Algoriddim would also give us the ability to set 8 cue points instead of just 4. That’s my main gripe after the otherwise terrific v2 upgrade.
Hey DJ Hombre,
Love your work and videos. :slight_smile:
If NS7 II is class compliant you can use midi learn on a mac and then copy that file into Djay2 folder on a jalibroken ipad. Btw, in case you haven’t already voted, there is a thread in the ideas section called Midi learn. I hope that it gets implemented soon as it would make life a lot easier for us with unsupported controllers.
This listing is for Brand New Numark NS7II DJ Controller. This is 100% new, never used and box never opened FOR $1,000usd.
CONTACT EMAIL:- WAIZ.HAMZA@LIVE.COM
BBM PIN: 280762CD
Features
7-inch motorized turntables with ultra-high-resolution MIDI (3600 ticks per rotation)
4-channel mixer and 24-bit audio interface built in
16 multi-color MPC® pads from Akai Professional
Capacitive touch-sensitive filter, EQ, and effects knobs
Genuine vinyl discs and real felt slipmats for unmatched tactile control
The most intuitive and seamless control for Serato DJ available
Connect and mix CD players, turntables, MP3 players, or any other external source
Mixer can operate standalone, with or without your computer
High- and low-torque turntable settings
Comprehensive Loop, Sample, Slicer, and Hot Cue controls
Strip SearchTM virtual needle-drop technology
Serato DJ software included
Curve-adjustable CP-Pro crossfader
Dedicated iZotope® effects controls
4-decks means more power in your DJ arsenal. Upgrade your setup today!
NS7II - 4 Channel DJ Performance Controller Specifications:
INCLUDES
NS7II Controller
Serato DJ Software (Download)
(2) Turntable Platters
Spindle Wrench
Spindle Screw
Allen Wrench
USB Cable
Power Cable
User Guide
Safety & Warranty Manual
For Purchase contacts Mr.Hamza
BBM PIN: 280762CD
Can I use the V7 motorized controller with vdjay?
Please support NS7II
Please support Numark v7 controller
