- Device model * Xiaomi Pad 5 Pro
- Version of operating system * Android 13
- Version of djay * 5.3.3
- Hardware/controllers used * Numark PartyMix 2
Your question:
I was able to test it on my Ipad, but I cannot have to make it work on my Xiaomi Pad 5 Pro tablet. Does Android version also works for Partymix 2?
Hi @MikaDee, welcome to the Community! Please note that this hardware is not currently supported on Android. For our full list of supported hardware on Android, please see the linked list below:
chegg:
Numark Party Mix 2 is not officially supported on Android tablets Use with a laptop and DJ software like Serato DJ Lite for best results.
Hi Jaw thank you for your prompt answer. Would you know if they will support it in the future?
Thanks Joy for the answer. Yes indeed it works well with PC, but my requirements is should be portable as tablet. I would like to use tablet instead since touch screen is a great add up on controls.
Hi @MikaDee, we are always looking to add support for new hardware across all platforms, but we don’t have a roadmap to share on this. So, I recommend that you choose hardware that is already on the list. I hope that helps!
Numark Party Mix 2 isn’t officially supported on Android, but you might get basic functions working with some DJ apps via USB OTG.
