Does Numark Party Mix dj controler can be used to control directly DJay Pro for Mac?
Are you planning support in the near future
How to do it please ?
Hello There.
what software you advise to work with Numark party mix
Jose
the Party Mix is not natively supported but you can map the controller easily via the midi learning feature.
Hi Lukas,
Thank you very much for the help
Tiago
I advise using virtualdj as it is natively supported
