Numark V7
Hi there, I used to dj with Serato Itch & Numark V7 turntable. I recently bought a Pioneer DDJ Wego 3 and purchased Djay Pro from app store. Do you have a midi map of Djay Pro for Numark V7?
Hi William,
thank you for your post.
Have you tried out the Midi Learning feature in djay Pro for the Mac? If you need some help mapping the V7 please contact our support via support@algoriddim.com.
Thank you,
cheers,
Did this work
