Hi guys, i’m an user of djay2 on iPad and i’m really satisfied with the available functions, for this reason I want to maintain this version for professional use and I never want to update it.
However I would like to try the new version of Djay on the same iPad where Djay2 is installed but without upgrade the old version.
Is possible this option and how can I do it?
Thank you very much for your support.
L
Don’t do it. Your beat grids will always be off.
I’ve been dealing with this since Djay Pro for 3 years now
I had to stop using djay 2
Refer to this link below,
Find my 3rd reply, the Algoriddim team Is aware of this issue, still a problem, I tested on Djay 2018 version.
http://community.algoriddim.com/algor…
happy to hear that you figured it out.
This is correct, you can still use the older djay versions. djay for iOS is not an update, it is a complete new application.
Solved by myself. The old and the new are two different apps so the Algoriddim proposal it’s not an update of Djay2 app but a special price for buy the new one.
Old Djay2 and new Djay can be used on the same device.
