Old Djay Pro 4 deck layout
Hi would you be able to add the option to use the Djay Pro 4 deck layout on the new version of Djay as its really difficult to mix all four decks as it only lets you have either the channel volumes or the fx and loops on the screen (Not using a controller)
Here are some photos Thanks
At least the key signatures…
Totally agree the old look is more comfortable and functionality.
