Hi there! I have been using Djay for several times on my Mac Mountain Lion with no issues with an Hercules MKII controller. Just bought a better controller from a friend: OMNI CONTROL. It features on your site has being one of the supported controls. Omni Control is able to “manage the mix” perfectly and i can easily assign controls. But on the devices it does not show up, therefore i am no able to pre-cue! Nothing shows up there!! Help needed! thks! Bellow pictures with the issue! Help needed!!!
We’re currently looking into this issue. I’ll keep you posted here.
Sorry, no news yet. Have you guys tried contacting Numark support yet?
Hi there. I have not contacted numark…device is working fine on traktor pro and Virtual DJ…could you contact them? I don ́t know the thecnicals, i believe the issue is with compatability of Djay on mountain lion on identifying the soundcard of the omni control
Any joy with this as I have the exact same problem. I can work around it using the split out cable but that’s not ideal!
i have the same problem its important to give us a feedback about this, tnks in advance.
