have an on-screen track search scroll bar for each turntable to quickly scrub through a certain part of music track?
Hi Jason,
You can already do this I believe.
I am doing this already in full screen mode on the Numark IDJ Pro.
When the track has calculated its BPM, you can actually touch the waveform itself and it will immediately jump the red line to that point in the track.
You can also then scrub the track by moving your finger left to right.
I did this four or five times already tonight when practicing setting up for a loop so I know it works.
I hope this helps, cheers.
Kind regards,
James
thanks james! i never knew this was possible lol
