I have a DDJ-WEGO3, Djay pro for iPad and an iPad 3 (using this cable http://www.pioneerelectronics.com/PUS … ).
When, on the WEGO3, I press Shift and Play making Track 1 play rewind; I cannot click play on Track 2 and make that track start playing.
Cheers
Hi Lukas, and thanks a lot for your reply!!
I tried the work around, and it worked once, but then it never worked again, trying multiple times (and I followed exactly your step-to-step instruction).
Cheers!
Lukas_E
January 13, 2016, 1:20pm
#3
Hi Dj Boum Boum.
thank you for this feedback.
We were able to reproduce this and I forwarded this behaviour internally.
In order to do so we suggest a work around by
pressing Play at the other deck
cueing the other deck by using the jogwheel
Shift+ Rewind the active deck
releasing the other deck by lifting your hand off the jogwheel
I hope this is helping, if not please contact us right away.
