One Button for launching specific Looper Rows
Hello there,
after Buying and trying 3 Different 8x8 Launchpads with additional dedicated Launch Buttons per Row.
Now my Problem:
THERE IS NO POSSIBILITY TO LAUNCH A SPECIFIC HORIZONTAL ROW (1-6) IN LOOPER.
i even miss this feature on Display!
So there is neither the Possibility to Map the Launch button to a midi Button (via cc/note) BECAUSE IT DOES NOT EXIST, only the button to stop or start the whole launcher…what if i wanted to launch the complete 4th row without touching all 8 Launch Buttons!!
NEITHER IS THERE A POSSIBILITY TO MAP MULTIPLE COMMANDS TO ONE MIDI BUTTON, WHICH ALSO HAD SOLVED MY PROBLEM
All Launchpads i used do not support that the row´s dedicated button is pressing all 8 buttons of the 8x8 Grid.
So i have to request it from software side, because no hardware is doing the trick without a dedicated mappable ROW-LAUNCH-BUTTON
This is my feature Request
Greetings and have a wonderfull day,
Stefan
Thanks for the suggestion @Stefan_Schanzenbache. I will pass this onto the devs for consideration. In the meantime, you could use the Duplicate function in the MIDI Learn tool to map all 8 Loops in the row to a single button. This would effectively achieve the same results. On iOS, you can access the Duplicate option by pressing and sliding left on the MIDI command.
Amazing i did not know about the left swiping.
Thank you for the solution
You’re welcome @Stefan_Schanzenbache
