OneLibrary does not export saved loops
DJAY Pro for macOS 5.6.6 - Macbook pro M1 Ventura 13.7.8 - Numark NF4FX + XDJ-AZ
On djay pro, I saved the output loops in the saved loop section, not in the cue point/saved loops section. Maybe that’s why on library only exports cue points?
Hi @jenoux, when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
Hardware Firmware Version:
No answer?
Was my question clear?
Hi @jenoux, I sent you a reply above 12 days ago asking for more information and didn’t get a response from you. I see now that you edited your initial post instead of replying. I do not receive notifications for post edits, only replies. So I had no idea you answered. My apologies for not checking back on this one.
Can you please share some screenshots to clarify if you are using Saved Loops or Cue Loops?
This is exported
This not exported
Thanks for the screenshots @jenoux. This clarifies things. After you export to OneLibrary from djay, what device and software are you importing into?
integrated Rekordbox of AlphaTetha XDJ-AZ with latest firmware
Thanks @jenoux, for this to work with Rekordbox, you need to use Cue Loops instead of Saved Loops in djay. Please refer to the linked section below from the macOS user manual for creating Cue Loops:
Thanks, that’s what I suspected, I have to change them all.
Is it possible to save them as active loops so that rekordbox imports it as an active loop instead of a cue loop?
You’re welcome. No that’s not currently possible unfortunately @jenoux
