OneLibrary on a SD card?
I’m currently trying to DJ on djay Pro ipad using OneLibrary. The app officially states that it supports importing OneLibrary and mentions SD card usage.
However, when I export a playlist from Rekordbox 7 in OneLibrary format and put it on an SD card, the latest version of djay Pro cannot detect or read the playlist.
I’m already convert my SD card rekordbox library to OneLibrary.
Even though RKB7 exports as OneLibrary, djay Pro doesn’t show it in the library when loaded from SD card. I have confirmed that the playlist and tracks are on the SD card and exported correctly from Rekordbox.
Has anyone successfully imported a OneLibrary playlist from Rekordbox 7 using SD card into djay Pro?
Do I need a specific folder structure, file format version, or additional steps for SD import to work?
Any advice or shared experience would be appreciated. Thanks!
Not sure of the specifics, but do you see the card and data from the native files app?
Hi @HUA, welcome to the Community! Sorry to hear you’re experiencing this issue. When creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
Please confirm that you are using djay 5.5.2. I see no reason why an SD card would not work in the same way as a USB flash drive. Perhaps its a format issue or permissions issue. Please refer to the linked FAQ below and let me know if that helps or not:
https://help.algoriddim.com/hc/en-us/articles/23070080061212-Using-OneLibrary-in-djay
Yes, I transfer files to the SD card without any problems. I record them on Windows 10 and export them to iPhone 12 Pro. The format of the exFAT card. Rekodbox 7 free version.
Thanks for sharing @Zirrex
