OneLibrary USB setup for CDJ-3000
Thanks @Michael_Wisniewski!
thanks Michael, what should I rename the library to. Just not that keen on opening Rekordbox !!!
You can use any name, changing the filename is the point. For example, change the name from export.db to → export.backup
