OneLibrary USB tracks to My Collection on Mac
Solution:
View / Show Library Side Bar
Drag files from OneLibrary usb to My Collection in Side Bar
  • 21 MBP M1
    Sequoia 15.7.3
    djay Pro 5.6.5
  • Step by step how to import tracks with cue points from OneLibrary usb to my collection on a Mac?
Video / images on how to do this on a Mac would be helpful. Thanks
Hi @ben446, please refer to the section below from the djay for macOS user manual and let me know if that helps or not:
Hi again @ben446. Did that macOS user manual section above help with your question?
No - I found the solution elsewhere and posted it at the top of my OP
Sounds good. You’re welcome @ben446
