I bought DJay yesterday and I can’t play the music or do some FXs with the mouse only the keys work. Is there a solution to that ?
Please click on and run “Software Update…”.
I just purchased the program. I cannot move the volume slider or change the volume and so on with the pitch too. I also cannot move the cross fader, and also the only way for the music to play is the space key since the play button won’t work. PLEASE HELP!! I don’t want to know i spend $20.00 on a program just to play a song.
Can’t change speed volume or anything! No sliders works!.
update my software on my mac. all is well now!! thanks for the help
Same problem here. Just got latest version, and no mouse controls work.
Songs won’t play in djay 4.2.
I am using a Macbook Pro (2007), OS X 10.7.3, iTunes 11.0.4 (4) and djay 4.2. I can’t drag songs onto the turntable. Songs only appear there when double-clicking them. But then not a single song will start playing when pressing the start button! All my songs are purchased on iTunes and loaded from the iCloud onto the internal hard drive. Please give me a feedback. Djay will be absolutely useless this way!
can not control with the mouse.
i can not control anything using the mouse.
i click over play button and nothing happens, or if i click on the fader it pops up the recording window…
