Hello,
Can this be added to the BPM, Key etc. option menu for playlist management.
Hello,
you can create a smart playlist, then use the filter “clean” on the title or comment box.
Thanks for the suggestion @E_Flem. I have forwarded this to the dev team for consideration.
Hello,
That’s true, but not what I’m asking for. I’m asking that it be an option in the drop-down menu. I can do the same with BPM and key, but it’s still an option in the drop down menu.
