Open djay pro the last setup I left it
Each time I reopen I have to reset up the way I happen to have had before I go live on twitch. It be great if I can just reopen it and it it be ready to go . I switch to iPad and besides that I’m loving djay pro even more
Hi @CrossFade1200, thanks for the feedback. Can you please be more specific and share all of the things you need to set up each time?
When I set up 4 decks view and turn the fader off for deck very 1st deck on my pad and the last deck . Then I close the app when I’m done djing and have to disable the crossfader for those decks again. Also is there a way to tell djay pro to not ask me if I want to setup control vinyl on my rane one?
Thanks for clarifying your suggestion @CrossFade1200. I have passed this onto our devs for consideration.
Regarding your DVS question, there’s no documented “don’t ask again” option for that prompt, unfortunately. The one setting that governs DVS is Settings > DVS > Enable DVS, and the manual explicitly recommends leaving it off unless you’re running timecode — so make sure that’s unchecked and see whether the prompt stops appearing. I hope that helps!
