Optimise screen size on Macbook
Hi
Apologies if this feature has already been asked for, but I couldn’t find it when searching the forums.
I use DJAY Pro on a MacBook Pro M3. Screen display is default at 1512x982 pixels.
I can’t use the application is full screen mode as, with the features I have enabled the library is too small to be useful at gigs.
Below is the view when I drag it to half my screen size. As you can see I can see around 15 tracks in the library, which is decent. I still have good visibiltiy of my hot cues and can see my waveforms. I’d like the top half of the app to remain the same height when I maximise it..
This is medium. as you can see the top half of the app is getting bigger and the library is shrinking
This is maximised. As you can see the library is only displaying 5 tracks.
Why do I keep the FX & Neural controls switched on?
The FX has a nasty habit of reverting to 3/4 loop instead of 1 bar, so I keep it there and fix it live. The neural view I’m not precious about as that works fairly rock solid.
Ways to fix this
  • Give us the ability to customise the layout and drag elements around, even resizing it or
  • Give us the Pop Library feature which is available on the iPad. When I use the track search function on my controller, pop the library as if I was hitting Enter on the MAC. When I’ve loaded a track, shrink back down again automatically. The idea is not to touch the keyboard at all during performance, which is possible if using the ipad, but then the Match feature is not available whereas it is on Mac.
Thank you
DJ Aluca
2 posts were merged into an existing topic: Resizable interface elements
Merged with existing topic: Resizable interface elements
