On the next update of djay for ipad, there should be an option to leave the ‘Key-Lock’ feature on at all times. It’s an unnecessary added step for each song and is sometimes easily forgotten.
Thank you.
Thank you.
We’re proud to present djay 2. Key lock now stays on in this new version.
I assume there is no way to have the keylock permanently on? it needs to be turned on with every new track. I hope you fix this in future updates.
Djay key lock doesn’t stay on.
when using idj live and syncing songs I must go into the bpm and turn on key lock for every new track kind of makes the sync button on the controller kind of useless. would be nice if there was an option to keep key lock on even through a new track to make syncing a lot faster and easier
Key lock remaining active through track switch.
Hi Andi,
at the Mac if you once activated the key lock it stays active till you turn it off.
And for the Mac version? Doesn’t seem to always stay on
