I’m using the latest Version on my Samsung s23 ultra and I tried everything but isnt there an Option to change the orientation of the waveform from vertikal to horizontal??? On ios and Mac it is possible but not on Android??? Why? If I choose the PEN Symbol on the waveform there is just an Option for contrast but no Option to change the waveform
Has this ever been resolved? Having same issue.
Hi. This is due to the limited functionality of the Android program. There is no Pro mode available.
I’ve been waiting for improvements for Android but I realized that I couldn’t wait and bought a used iPhone.
On iOS, the program has more features.
No one knows when the same features will be available on Android. They only tell us that they are working on improvements.
Hi @David_Tran, we do not currently support changing the waveform orientation on Android.
Bonjour l’ équipe,
Ça serait top de pouvoir positionner les waveforme à l’horizontale, pour moi, il ne manque que ça sur Android pour avoir un visuel optimale.
Bonne journée
Hi @Sebastien_Soyeux, please translate your post into English. Thanks.
Hello Djay Team,
I’d like to suggest this feature for the Android version of djay.
Would it be possible to add a full-screen waveform view, where the waveform occupies most or all of the display? Maybe like double tap on it, then go full screen and back with a single tap.
As I’m getting older, reading small details on the screen while DJing is becoming more difficult, especially when switching attention between the device, the controller and my headphones. A full-screen waveform mode would greatly improve visibility and make beatmatching and track monitoring much more comfortable.
I imagine this could be an optional view that users can enable when needed, particularly useful on andriod phones and smaller tablets like mine.
I believe this feature would also benefit many DJs with presbyopia or other vision limitations.
Thank you for considering this suggestion.
Thanks for the additional feedback @Ramsey
