Option to disable repetitive “Neural Mix not available with Spotify” Pop-up
Dear Algoriddim users and Team,
Since the release of djay version 5.4.3., Spotify integration has been reintroduced, which is fantastic and very welcome. However, it has also introduced some usability issues that can become quite disruptive during live performances.
As you know, whenever a function or effect that relies on Neural Mix is invoked while using Spotify as a source, a message appears stating:
“Neural Mix cannot be used when streaming from Spotify. This feature is currently not available on this streaming platform.”
The reason for this limitation is clear, but the problem is that this message appears every single time one of these functions is triggered, for example with a lot of Manual or Instant FX, Neural EQ, or Neural Mix waveforms, and it blocks the entire screen, even mid-performance. That can be quite frustrating.
Because it’s easy to forget when using mixed sources (local + Spotify), the pop-up often reappears multiple times during a set, not because I’m getting old, but simply because I mix both types of sources. I would much prefer that the effect just didn’t work silently, without disrupting the rest of the performance. Right now, it interrupts the workflow and overall performance flow.
My suggestion:
Please consider adding an option to disable or suppress this message after it has been shown once, for example a “Don’t show again” checkbox or a setting in Preferences.
This would greatly improve the live performance experience without reducing awareness of the Neural Mix limitation on Spotify tracks.
>>Everyone who likes this idea, please vote for it in the upper-left voting box.
And on top of this.. when you accidentally trigger a Manual FX that assigned to a stem while playing a Spotify track, the stems mapping automatically resets to the full track. Even after switching back to a local track, it stays that way and doesn’t revert to the previous setting.
So not only do you get the pop-up message, but your effect mapping changes and you have to manually fix it before continuing, which can be very disruptive during a live set.
I just use Tidal. Same music with neural mix, no pop ups and no interference.
I don’t think that would improve the live experience. If I activate a Neutral Mix effect and nothing happens, I find that just as irritating, maybe even more so, because you have no idea why it’s not working. Sure, everyone is different, but if I really want to use Spotify, whether alone or together with other sources, I would completely do without Neutral Mix, just to avoid that. Alternatively, there’s Tidal…
Hi @Chris_R,
Thanks for sharing your insight and perspective on this. I totally understand where you’re coming from.
I think both views can actually work well together. The idea of adding a simple “Don’t show again” checkbox would let everyone choose what fits their workflow best: you could keep the pop-up if you find it helpful, and I could disable it to avoid interruptions during a set. Best of both worlds!
My main concern isn’t the message itself but how disruptive it becomes when it pops up repeatedly and even resets effect mappings mid-performance. So an optional toggle (or at least making it less disruptive) would make everyone happy without removing any functionality or clarity.
Thanks mate!
That’s great to hear @daniel_curley! But since I already have Spotify Family for the kids as well, I’m not planning to switch to Tidal or subscribe to both.
Thanks for the feedback @DJ_Big_Blender, I’ve shared it with the devs for consideration.
Would it be possible to switch automatically between two views?
One view: Neural Mix-Setting (EQ, FX, etc.) and a second default view without Neural Mix Effects and EQ?
I think this might solve a big issue at Djay Pro at the moment. Now you have Spotify on iOS, which everybody loves. But you also have the best stems separation on the market. As it is not possible to use both at the same time, I try to play mostly local tracks to have all Neural Mix effects (and EQ). Tracks I don’t own, I’m switching to Spotify, but then I forget to switch the EQ mode and get this ugly pop-up. It would be great to have an automatic switch to “normal” EQ mode, if I load a Spotify track. And a switch back to Neural Mix, if I load a stem-supported source. Same for the instant effects (if possible, a complementary effect without specific stems).
Thanks for the suggestion @Christian_N. Good idea! I’ll share this with the devs.
Like I said, the manual effects that includes Neural Mix is even worse.
The Neural mapping to a stem disappears when loading a Spotify track, which is fine. I have no problem with that.
The problem is that the assignment to that stem doesn’t return afterwards when loading a local track again. It just stays gone.
I think that results in a poor user experience. Could something be done about this?
Thanks for the additional feedback @DJ_Big_Blender. I’ve shared this with our dev team.
Commenting here to plus one, but also to suggest that an internal toast notification that just flags and then disappears without interrupting or requiring a modal interaction, for this as well as other operations would be ideal.
For example, if I accidentally want to load into a track that is playing, I can’t cancel the modal that shows up, unless I go to my mouse or keyboard, which totally disrupt and interrupts the flow.
If that modal button was at least mappable to a midi operation, then I could set a midi button instead of having to reach all the way over to my laptop anytime it happens.
Hope this helps.
Thanks for the additional input @TEEE. I’ve shared this with our devs.
Hi @TEEE :laughing: :teacup_without_handle: ,
Yes, that’s a good one as well.
Why do they place an interrupting modal that requires a modal interaction? That’s not user-friendly at all. Hope this will be improved very soon.
