Is there a way to do it?, if not it be very helpful in mixing…a thought
Hi Bryant,
This is currently not supported, but you can skip the silent part at the beginning of the song like this:
- Set the white cue point where the song should start
- Tap the gear icon, go to “General” and enable “Jump to Cue point”
The next time you load the song, it will automatically jump to the cue point (and start playing from that position).
