Option to set end cue point
Allow and end cue point to be set.
Looks like this was answered already - setting end point in iTunes should be applied on iOS
The track end point (as set in iTunes) is not considered / honoured by dJay, which is not what you expect.
Please can this be supported and execute as per iTunes please.
Had there been any more consideration to adding this request?
thanks
Hi alex cumbers,
thank you for sharing your feedback.
We noticed your request and added your request to our user request list.
The iTunes start and end points are not considered and can not be considered at the moment. I added your request as a feature request for an iOS Set End Point, hope this works for your too.
Cheers,Lukas E.
