The most recent update included a redesigned library schema and it appears that there are a few orientation bugs when using the IDJ Pro.
This issue remained after a full reboot and reload of software. Tested it with IDJPro on before and after Djay software had loaded.
The rest of it works amazing. Thanks for the free update, bought the sample packs immediately
