os status error message
I keep getting an oss error message that prevents me from loading music not purchased through iTunes! How do I fix this? I think it’s pretty stupid that this is type of error is even happening on a supposedly “Pro” product for Mac.
this is the message I’m getting: The operation couldn’t be completed. (OSStatus error -54.)
Right click on the track and show in finder… will it play there.
Adrian is right… that’s what that error means.
The “OSStatus error -54” comes up whenever a file can’t be located on your Mac. Can you please try playing the concerned songs via iTunes to see if they have been moved within your storage?
The songs play on iTunes and even after I reset, organize, analyze and refresh everything on both itunes and Djay. I get the same error.
Thank you!
