" OSStatus error 2003334207"
No itunes tracks will play.
Spotify works fine.
I have read the comments from other posts on this problem, nothing has worked.
Any updates?
thx!!
Hi Shauna,
Can you please tell us which djay version and device you are using?
Hi Shauna,
hello, I have the same problem and I use the version djay pro 2 2.0.15
Djay Pro
MAcbook Pro
I seemed to have solved the problem. A restart, I think…to be honest I can’t remember!
I believe that I did a simple restart of computer. It was awhile ago and I can’t remember.
Good luck!!
I have also had Spotify stop working. That ended up with me needing to re sign in on Spotify and all was back to normal.
