I’m a little confused about something check out the video. Essentially the output head in settings when I change it from none to all the different options it affects the input gain of the channel I’m a bit confused why this is, is this normal behavior?
Hi @Nubium, to share a video please upload it to your Dropbox/Google Drive, enable sharing permissions on the file, then share a link to the file here. Thanks!
Hi @Nubium, thanks for the video. That’s super helpful. I’m in discussions with the engineering team regarding this and will report back when I have more info.
So are you saying that in the app when it says output, headroom, it means the output from the app to the controller not the output from the controller left and right stereo outputs?
