Overheating and freezing on iPhone 15 Pro Max
Guys, I do some DJing on DDJ-FLX4 using the iPhone 15 Pro Max and I’ve noticed that the iPhone overheats and then the app freezes or only the left side of the console works.
Hi @Edvaldo_Souza, welcome to the Community! When creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
Hardware Firmware Version:
Is the FLX4 also connected to power or are you running it off the iPhone internal battery?
If connected to power, are you using your original iPhone charger and cable?
I had this happen with a Macbook Air and iPhone at an extremely hot tropical beach wedding. Solved very quickly by borrowing an electric fan and having it blow directly on the laptop and iphone.
(And of course, keep all electronics in the shade, out of direct sunlight.)
