pause between tracks
hello, is it possible with djay pro 2 to add a pause between the tracks. i use dj pro 1 for dance events and there its not possible. i need to have 5-10 sec. pause between the tracks doin automix.
So if I understood correctly you need 5-10 s pause i.e no audio at all between tracks.
Quickly looked and tested.
There is a automatic, fade, eq, filter, echo brake and reverse kind of transitions, but not really a pause between tracks.
Not optimal, but you can always use https://github.com/anars/blank-audio
