Phase display
Phase display! Very helpful in Traktor Pro and Mixvibes. Would be great to have on the iPad app
Hi Jay El,
can you tell me in detail for what you are using the Phase Display, thank you for sharing.
I’m not 100% sure what you mean. Do you mean what am I using the phase display for? It’s to show that the two playing songs aren’t just synced it terms of beats, but that the 4 bar (mostly, occasionally 6) phase is also synced. Very important to mix tracks in phase!
