Phrase Sync ( ddj200)
Hello, I use ddj200 and it has a phrase Sync function. I can’t figure out how to use it with Djay.
Thanks in advance
Hi @Yan, welcome to the Community! djay does not currently support Phrase Sync. In the djay Settings>General>SYNC MODE you can, however, change the Beat Sync Interval from 1 Beat to 4 Beats which should help with maintaining phrasing when using Sync. I hope that helps!
Do you think this function will be available in the near future?,
You’re welcome @Yan. The dev team is constantly adding new functionality to djay so it is of course possible. However, we do not generally share roadmaps of timelines. In the meantime, there is an existing suggestion topic below where you can vote to have Phrase analysis implemented. I hope that helps!
https://community.algoriddim.com/t/can-we-have-phrase-analysis/23688/3
