Now Djay for Macbook is supporting Pinoneer Wego Controller. Are there any plans to add the controller support for Djay iPad version?
@Branden, the reason why the WeGo or Ergo isn’t supported for the iPhone / iPod Touch is because these are USB controllers…currently, the only way to connect them is via a USB hub / USB cable (like the DJC-WeCAi). You could possibly connect it via a Vestax V-Midi but that doesn’t transport audio over USB.
Ideally the DJC-WeCAi cable would not use the CCK and have a standard Apple adapter…but not this time round.
Use of the CCK is only allowed with an iPad - Apple’s rules I’m afraid and outside the control of Algoriddim.
Hi Thomas,
I changed your question into a request.
i just wasted my money on this app because it said that it supported wego… only to find out that the version i got (iphone) doesnt. you should fix this. i wouldnt have wasted my time & money if i knew i couldnt use it. i already have pcdj for the computer…a REAL dj program.
i needed something for my phone as backup. now im just out the$$$
I upgraded the wego firmware and it worked for me.
I Just got The cable for iPad & wego and does not Works. IT says that The device i Just plugged in needs moré Power!
I has conected The Power USB To many Power Supplies and stills The same problem.
Do you know how To resolve this?
