Do any Pioneer controllers work with Djay Pro2 and RekordBox and also have USB input support?
Thanks. I was wondering if there was a Pioneers product that would work with both.
Hi Will,
Thank you for your post.
You can find all Pioneer controllers which are supported by djay Pro 2 for Mac on our Hardware website:
https://www.algoriddim.com/hardware
Cheers,Lukas E.
Hello, I would like to know how to connect my Pioneer DDJ-400 to DJ Pro using Spotify music.
