Pioneer DDJ-1000 CUE problem
Djay pro for windows has no form or does not recognize the sound plates of the DDJ 1000 controller, and multiple channels cannot be assigned, nor can the CUE
any solution?
as stated on our hardware site, Pre-cueing via the controller is not supported, but headphones can be used via the PC’s built-in audio output.
Cheers,Lukas E.
Hi Ariel Assayag, I have the same issue with Mac iOS.
Did you map your controller manually or is there a downloadable file to map the controller to Djay Pro?
