I have seen the thread on compatability for windows and an admin. Asking if android and ios support was required… support for android. Have an ddj-sb3 atm but looking for a controller compatible with software. The Mixon looks… o.k. but would prefer the flx-6…
Hi @Adam_Howarth, can you please clarify your question? Are you asking if the FLX6 is supported on Android OS?
To clarify, the Pioneer DJ DDJ-FLX6 is currently supported on macOS, iOS and Windows. It is not supported on Android OS. You can find a list of currently supported hardware for each OS below. Be sure to select your OS to reveal hardware for each one.
