Pioneer DDJ RB
Hi guys, I just got my Pioneer DDJ RB, everything works just well, but one thing bothering me. How get sound throug controller not though the Mac.
Check this …
http://download.algoriddim.com/manual…
Section 4.8.2 … Configuring Audio Devices
Did you install the designated driver:
https://www.pioneerdj.com/en/support/software/DDJ-RB/
Always make sure that you have downloaded the designated driver if your controller requires a driver to work with your system.
Cheers
Cheers
Are you saying through PC? I have Aspire R7. Tell me what is going on.
You have buy this speaker the “iwave Model: CBD-0901500” and the “Pasow 3.5mm Stereo Male to 2RCA Male (Right and Left) RCA Audio Cable (15 Feet)”
The wire is cheap and it works well and if you want the expansive one then get the 12 dollar one. All the products are on amazon.
use you headphones for the product. Is this what you mean?
Ok , controller has audio output (RCA), and 3,5 mm jack for headphones. I bought RCA wire and conected to my speaker system and to my controller. I tried to change settings in Djay pro but nothing is changed! Sound goes through my MacBook not through speakers.
Sorry for my English!
I know how it should work, but this what I see!
I have the same problem!!! HELP please!!
