Pioneer DDJ RZX MAPPING
  • Device model: MacBook Pro
  • Version of operating system: 10.15 Catalina
  • Version of djay: 5.1.3
  • Hardware/controllers used: Pioneer DDJ RZX
My name is Pro DJ ELjay from NIGERIA
I actually configured the mapping on my DDJ RZX and it works perfectly fine but channel line fader monitor light is not coming on and am not okay with it because it has to be monitored
Secondly the three display screen is not showing anything aside rekordbox on the left and right side and the middle display screen only showed usb connected no wave showing there, had to be looking at my laptop screen to perform mixing
The jog vinyl monitor is not also showing, it only displayed vinyl and had to be looking my laptop screen before I can scratch perfectly…
And am able to setup keyboard shortcuts to make it work perfectly like serato keyboard shortcuts but I couldn’t found the shortcut to locate current playing song which is (CMD+L on Mac) and (CTRL+L on window)
I think that’s all and let me know if you need the mapping setup to have yours configured
