I have a DDJ-SR that I am using with DJ PRO (Mac) and I am unable to get the FX to work on the buttons on the DDJ-SR. It seems they might not be mapped properly. Does anyone else have this problem? Do I need to configure something in the software? At present the only way I can get some FX going is to use the trackpad on the laptop as the buttons on the Pioneer can’t instigate the desired effects.
I was wondering if you’ve found a solution yet because I’m having the same problem. I’ve been able to use the other functions of my DDJ-SR, but I’d really like the use of my fx back (as I had when using Serato). Please advise. So far I appreciate the user friendly interface of DJay Pro for Mac. Thanks.
