Pioneer DDJ-XP1 MIDI Mapping
I create DDJ-XP1 mapping base on DDJ-XP2 mapping from preload in djay Pro.
This mapping have HOT CUE 1-16, HOT CUE Pitch Play, FX Pad, Beat Bounce, Beat Jump,Neural Mix/Play Control and Sampler/Looper and all 4 deck.
Change some pad color and layout base on rekordbox and djay UI/UX.
Test mapping on iPad and Mac.
Download.
Thanks for sharing @VJ_Xess. Nice work!
@Slak_Jaw There are some parameter like “Deck Switching”, “customProcessor.pioneerDDJXP2SetDeck” in DDJ-XP2 mapping.
What this stand for? May be about special USB HID?
Can you give me a advice to make mapping better?
Hi @VJ_Xess, I don’t have that hardware so I’m not sure unfortunately.
My mapping XP1 Download
Great! Thanks for sharing @DjPiloto
This hardware is now supported with the latest djay 5.5 release:
  • Added native plug-and-play support for CDJ-3000X and XDJ-1000MK2 (macOS, Windows), and DDJ-XP1
Has anyone in the community created documentation on the algoriddim XP1 map? Its my understanding that algoriddim does not make that available.
