Pioneer DJM-S11/Neural Mix EQ
Hello,
Some time ago I asked about support for using the Pioneer DJM-S11 EQ knobs (HI/MID/LOW) to control Neural EQ in djay Pro, and at that time it wasn’t supported.
I just wanted to ask if there have been any updates or changes regarding this feature.
Is this something your team is considering for a future update, or is it technically not possible?
In this video, the boy wrote the code himself, and everything works for him—and the standard EQ doesn’t affect the sound!
Hi @Polyura, thanks for checking in. We don’t have any updates to share regarding NM EQ support on the S11. Perhaps this will be possible to achieve in a future update, but I don’t have any information to share regarding future developments.
Hi @Slak_Jaw,
Thank you for your reply.
I completely understand that you can’t share unannounced features.
I just wanted to ask if you could check internally whether Neural Mix EQ support for the DJM-S11 is at least being considered, or if it’s currently not on the roadmap.
The S11 is a significant investment, and this feature would make a huge difference in my decision to purchase one. I know I’m not the only DJ requesting it.
Even if you can’t provide details, knowing whether it’s something the team is actively considering would be incredibly helpful.
Thank you very much for your time!
You’re welcome @Polyura. Unfortunately, we don’t have any additional information to share about this. My recommendation is not to purchase something in hopes of a future feature addition if that feature is critical to you workflow.
