Pioneer Mixers and Djay Pro (iPad)
  • Device model: 2020 iPad Air 4th Gen)
  • Version of OS: iPadOS 17.5.1
  • Version of djay : 5.2
  • Hardware/controllers used (e.g. Reloop Mixon 8 Pro): Pioneer DJM-A9
Hi, I am new to Djay Pro, so far loving it. Here is my question:
Can you (and how) use a certified for Djay Pioneer mixer, for example the DJM-A9, configuring Djay in iPad for External mixing, with the intention to pick a couple of mixer channels for each deck.
If it’s possible, is there any min firmware version on the mixer? is there anything else to hook or install on the iPad?
Hi @jorgelectro,
Thanks for sharing your question in our community.
Since the A9 is supported in djay for iOS as shown on our DJ Gear page, you can use the controller with your iPad with the exception of PRO DJ LINK Bridge for connecting CDJs.
We suggest you keep the controller and your iPad up to date with the latest firmware and OS versions as well to prevent any potential issues.
