Device model (e.g. 2020 iPad Air 4th Gen) :
Version of operating system (e.g. macOS 14.4.1) :
Version of djay (e.g. 5.1.2) :
Hardware/controllers used (e.g. Reloop Mixon 8 Pro) :
Hardware firmware version (e.g. 1.0.1) :
Please consider sharing a short video or screenshots to help clarify your question
YOUR QUESTION:
Does anyone have a list or pdf of the native midi mapping for the Rev7?
Hi @DJKeebs , welcome to the Community! We do not currently have a MIDI mapping key for this hardware. However, you can easily check what anything is mapped to by using the built in MIDI learn tool.
If you're not using a supported MIDI controller, MIDI mapping gives you full control over how your hardware interacts with djay Pro. You can assign every button, knob, and fader to the functions you use most. This flexibility lets you shape djay...
Thank you the response. I don’t have a Rev7 yet. I’m debating buying one and would like to know how it’s mapped before making the purchase.
Understood. As I said, unfortunately we don’t have a mapping key for this hardware. However, the mapping should be pretty similar to other software.
