I’m looking to use djay pro on my MacBook Pro, connected to a pioneer v10 with two turntables using dvs and two cdjs 3000. I may potentially expand out into a djs1000 into the future.
Just wondering whether this kind of setup is possible with djay pro? Also could someone explain the limitations of the v10 not being supported by djay pro. Does it mean I have to do the mappings myself or is there more to it than that?
i’m interested, too. i saw on YT, that AlphaTeta’s Euphonia will be supported, although inofficially. So there might be a chance for V10 as well once it seems to be based on same technology.
You’re welcome @ctdfuk. You should confirm with Pioneer if this mixer is DVS compatible without an external soundcard. The DVS CD’s must use a control tone of 1kHz to work with djay. So, if that’s is what the Serato CD’s use, then they should work.
