Firstly a massive thank you to the staff over at Algoriddim for bringing such an amazing app to the market. I got an iPad recently and then discovered DJAY and I’ve been mixing daily since… I took it to the next level and got a Pioneer Wego2. Only issue is that there’s no trim dial! You get 3 low/mid/high dials but no ‘master’ dial.
Would it be possible to add the functionality within the iPad app to map the trim dial (which is available in the app) to one of the physical hardware buttons? I’m thinking perhaps hold shift and use the platter to trim up/down.
