Hello,
Can I use a pioneer wego 2 with spotify ???
I have spotify premium and I can buy a used wego2 (ipad integrated version)
But I can’t find information about it!!
Hello,
please note that the WeGo 2 is iOS ready as well, so you can simply connect your iPad to it while charging the Controller via the USB Midi Connector.
Spotify is accessible with djay 2 and djay Pro at the iPad.
Only for Mac I believe
http://www.algoriddim.com/hardware
No I don’t believe it will
So with my IPad it will work… ?
