Pioneer Wego4 new controller is not compatible with Djay Pro
Hi, I have acquired a controlling wego 4 but apparently are not available Djay Pro native drivers on the official website.
We know the time will get a version with new drivers?
Thank you.
the WeGo4 is mappable with djay Pro for the Mac, but the native support is not yet implemented. Please be assured that the native mapping is coming with the next update soon.
We are doing our best in order to provide the update as fast as possible.
the DDJ WeGo 4 is now officially being supported by djay Pro 1.4.1.
Thank you for your patience and have fun mixing.
Hi Dean,
which iOS version are you using?
When is that update planned?
Very nice! It is working now as it should!
Thanks in advance!!!
Actually I have the same problem with a Pioneer DDJ RB… You say it is compatible with DJay Pro, but it doesn’t work! Now I want to change it with a WeeGo 4, but it’s not sure it works fine with DJay Pro…
Hello I cannot get my Wego 4 to control either Djay2 or pro. I have reinstalledd app. It’s showing Wego in the settings on the app and plays sound through the controller but I cannot use any of the functions.
Please help, very frustrated.
I have an Ipad mini which I bought for the Wego4, it’s running 11.1.1. It works on my old Ipad, I’m presuming Ipad mini is not compatible?
