Using pioneer xdj-rx3 regularly with djay pro I realized that if you use the mixer in midi mode the software cannot be configured with the correct outputs. Why?
In hardware mode, the RX3 is doing the mixing, so the outputs go directly from each deck to the mixer. In MIDI mode, the mixing is performed by djay’s software, and the outputs are master/headphones.
It’s not a fault or bug. That’s the way it’s supposed to work.
Hello! It’s been more than 7 days since my last reply. I’m going to consider this topic completed for now so I can focus on others. However, please feel free to respond and we can definitely revisit this. Thanks!
