So I have seen previous posts saying that it is supported but it’s really not.
When using Djay pro with the XDJ XZ you will be able to use it on laptop only, there is no driver that works on iPad/iPhone for the XDJ XZ so when used with iPhone/iPad, it’s buggy and again doesn’t work as they claim
And as it really only works on laptop
it’s still is not worth using due to the fact, stuff like jog wheel info is blank, the built in XDJ XZ screen is blank there’s no wave form track info like when used with serato , whilst using DJay pro, the mixer is not midi mapped to the controller, I was hoping this all would work cause it looked and sounded like the perfect app to use a iPad, and be able to use my technics with DVS along since my XZ controller and have everything linked together through Djay pro, it’s doesn’t, hopefully
in future this is all sorted out but for now I’d suggest sticking with serato untill these guys create something actually compatible with the XDJ XZ
